[Qgis-developer] QGIS compiling with Qt5 and Python3 on Debian
Médéric Ribreux
mederic.ribreux at medspx.fr
Sun May 29 01:19:15 PDT 2016
Hello devs,
I am developping for QGIS under Debian Stretch and I have tested the
qt5/Python3 port of QGIS.
But I am facing a problem with python3 plugin ports:
* I use PORT_PLUGINS CMake parameter.
* With this parameter, plugins are "auto-ported" to Python3 with 2to3
tool.
* The result of the "port" is made in the output directory of the build
directory (output/python/plugins).
* But it seems that `make install` takes directly files from the code
directory instead of the build directory.
* This leads to install python2 version of the plugins instead of
python3 version and plugins just crashes at QGIS opening.
I am a CMake newbie so I would like to check if I have not forgotten
anything.
Do you have the same behavior ?
Cheers,
PS: I can't find something that installs/copies python3 plugins files in
install prefix directory in python/plugins/CMakeLists.txt...
Le 2016-05-27 17:01, Sebastiaan Couwenberg a écrit :
> On 05/27/2016 04:57 PM, Yves Jacolin wrote:
>> On Friday, May 27, 2016 10:49:55 Sebastiaan Couwenberg wrote:
>>> On 05/27/2016 07:15 AM, Paolo Cavallini wrote:
>>>> apt-egt install git build-essential cmake flex bison pyqt5-dev
>>> s/apt-egt/apt-get/, the documentation has this typo too.
>> Any link? I can't find it :)
> It was in the initial commit:
> https://github.com/qgis/QGIS/commit/36161fc05dd869f7da9ccaad843105e71b9a5af7#diff-6a755e7d228a2b491321dbae0a7a248bR347
> But has since been fixed:
> https://github.com/qgis/QGIS/commit/84c0241776cdbc98e5ee27d5af98d7605badcec4#diff-6a755e7d228a2b491321dbae0a7a248bL348
> Kind Regards,
> Bas
Médéric RIBREUX
https://medspx.fr
