[Qgis-developer] Advenced digitizing rotate tool warps geometries
roy roy royroge at outlook.com
Mon May 30 03:54:29 PDT 2016
As per subject the advanced digitizing tool warps
the geometry when used, e.g.
draw an orizontal line and rotate till it's vertical or almost vertical
confirm the action and the line will be much longer; this will
happen also with areas.
I've searched in the bug traking system and could not
find this possible bug, if you can confirm i'll open a ticket
thanks, Roy.
