[Qgis-developer] Advenced digitizing rotate tool warps geometries
roy roy
royroge at outlook.com
Tue May 31 01:14:35 PDT 2016
I notice that this only happens if you are using a
geographic coordinate system for the layer,
it seems ok with projected systems
Il 30/05/2016 12:54, roy roy ha scritto:
> As per subject the advanced digitizing tool warps
> the geometry when used, e.g.
> draw an orizontal line and rotate till it's vertical or almost vertical
> confirm the action and the line will be much longer; this will
> happen also with areas.
> I've searched in the bug traking system and could not
> find this possible bug, if you can confirm i'll open a ticket
> thanks, Roy.
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
