[Qgis-developer] plugins connection refused error
DelazJ
delazj at gmail.com
Tue May 31 02:34:51 PDT 2016
Thanks, Alessandro.
Don't know if it's related to recent changes (never checked that before)
but my plugin manager settings currently show 2 repositories listed, both
linking to the official repo url. The only difference is their name ("QGIS
Official Plugin Repository" and its translation "Dépôt Officiel des
extensions QGIS" in french). The system locale is french but I'm currently
working with an english localized QGIS version.
I can simply delete one row but wonder if I should file a ticket...
2016-05-31 11:14 GMT+02:00 Paolo Cavallini <cavallini at faunalia.it>:
> Il 2016-05-31 11:04 Alessandro Pasotti ha scritto:
>> For anyone experiencing this issue:
>> the problem is now fixed but you must use a fresh XML file or you will
>> still try to download the plugins from the wrong URL stored in the old
>> broken XML.
>> In the plugin manager settings there is a button to reload all
>> repositories, that will probably fix your problem.
> It works, thanks.
> Paolo Cavallini - www.faunalia.eu
> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160531/3687d27d/attachment.html>
