[Qgis-developer] SpatiaLite layers not displaying in QGIS 2.14, works ok in QGIS 2.8
Christophe Damour
sigeal at sigeal.com
Tue May 31 08:23:18 PDT 2016
I posted an issue about once month ago about SpatiaLite layers not
displaying in QGIS 2.14 whereas they do in QGIS 2.8 :
https://hub.qgis.org/issues/14626
This issue has been corrected by Jürgen - thanks so much to him - but
the target version is 2.16.
As 2.14 is meant to be next LTR, I wonder if the patch could be
backported in next 2.14 point release ?
Christophe
Le 31/05/2016 à 11:34, DelazJ a écrit :
> Hi,
> Thanks, Alessandro.
> Don't know if it's related to recent changes (never checked that
> before) but my plugin manager settings currently show 2 repositories
> listed, both linking to the official repo url. The only difference is
> their name ("QGIS Official Plugin Repository" and its translation
> "Dépôt Officiel des extensions QGIS" in french). The system locale is
> french but I'm currently working with an english localized QGIS version.
> I can simply delete one row but wonder if I should file a ticket...
> 2016-05-31 11:14 GMT+02:00 Paolo Cavallini <cavallini at faunalia.it
> <mailto:cavallini at faunalia.it>>:
> Il 2016-05-31 11:04 Alessandro Pasotti ha scritto:
> For anyone experiencing this issue:
> the problem is now fixed but you must use a fresh XML file or
> you will
> still try to download the plugins from the wrong URL stored in
> the old
> broken XML.
> In the plugin manager settings there is a button to reload all
> repositories, that will probably fix your problem.
> It works, thanks.
> Paolo Cavallini - www.faunalia.eu <http://www.faunalia.eu>
> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
> Qgis-developer mailing list
> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160531/b72231fe/attachment-0001.html>
