[Qgis-developer] About QGIS-*.DMP files in Temp folder on Windows
geodrinx at gmail.com
Wed Nov 9 23:36:49 PST 2016
I had crashes also without loading any shp or other, and without any plugin (I tried also deleting .qgis2 folder and with --noplugins option in starting cmd)
Yes I trached in qgis issues many times, but it was closed without any fix, and the "minidump" title was renamed.
So, I am tired. :(
Please, try yourself to insert the issue and see what will happens. If you need some dmp file, I backupped them, and I can send how many you and others need.
Regards
Geo
Inviato da iPhone
> Il giorno 10 nov 2016, alle ore 08:14, Bernhard Ströbl <bernhard.stroebl at jena.de> ha scritto:
> Hi,
> just a notice: I experience crashes while zooming if geometries are invalid. As soon as I fix them the crashes stop.
> Setting: Geometries from PostGIS with ST_IsValid(geometry) = false, QGIS 2.* 64bit on Win7
> So it could be worth to check your data.
> Bernhard
>> Am 09.11.2016 um 21:37 schrieb Jonathan Moules:
>> Hi,
>> Have you reported it to the bug tracker - https://hub.qgis.org/issues -
>> That's the best way to report this sort of behaviour. While I can see
>> why a dmp file would be useful, no program should be leaving GB of dump
>> files behind.
>> Maybe it should clean up when there are more than x number?
>> Cheers,
>> Jonathan
>>> On 09/11/2016 11:28, Geo DrinX wrote:
>>> Good morning,
>>> purging my PC, I found 1595 files named "qgis-*.dmp" in my Temp
>>> folder.
>>> Totally, they amount to 36 giga of space :(
>>> For example, I have many of:
>>> myUSER\AppData\Local\Temp\qgis-20140915-160805-11200-8480-c3a2817.dmp
>>> each of 23 mega.
>>> So, for each quitting of QGIS since 2.18 from september 05 2014 I
>>> had a crash (also without any plugin installed).
>>> Also, randomically I had crashes.
>>> So, now I am deleting these files, to have space sufficent in my PC to
>>> work.
>>> I hope this can be sufficient for you to start a good debug of this
>>> problem, that I have reported more than once.
>>> If you need, I can share that files with you (also if I don't know how).
>>> Best regards
>>> Geo
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> __________ Information from ESET Mail Security, version of virus
>> signature database 14417 (20161109) __________
>> The message was checked by ESET Mail Security.
>> http://www.eset.com
> __________ Information from ESET Mail Security, version of virus signature database 14419 (20161110) __________
> http://www.eset.com
