[Qgis-developer] About QGIS-*.DMP files in Temp folder on Windows
Bernhard Ströbl bernhard.stroebl at jena.de
Wed Nov 9 23:14:07 PST 2016
just a notice: I experience crashes while zooming if geometries are
invalid. As soon as I fix them the crashes stop.
Setting: Geometries from PostGIS with ST_IsValid(geometry) = false, QGIS
2.* 64bit on Win7
So it could be worth to check your data.
Bernhard
Am 09.11.2016 um 21:37 schrieb Jonathan Moules:
> Hi,
> Have you reported it to the bug tracker -  https://hub.qgis.org/issues -
> That's the best way to report this sort of behaviour. While I can see
> why a dmp file would be useful, no program should be leaving GB of dump
> files behind.
> Maybe it should clean up when there are more than x number?
> Cheers,
> Jonathan
> On 09/11/2016 11:28, Geo DrinX wrote:
>> Good morning,
>> purging my PC,  I found 1595  files named   "qgis-*.dmp"  in my Temp
>> folder.
>> Totally, they amount to 36 giga of space  :(
>> For example, I have many of:
>> myUSER\AppData\Local\Temp\qgis-20140915-160805-11200-8480-c3a2817.dmp
>> each of 23 mega.
>> So, for each quitting of QGIS since 2.18  from  september 05 2014  I
>> had a crash (also without any plugin installed).
>> Also, randomically I had crashes.
>> So, now I am deleting these files, to have space sufficent in my PC to
>> work.
>> I hope this can be sufficient for you to start a good debug of this
>> problem, that I have reported more than once.
>> If you need, I can share that files with you (also if I don't know how).
>> Best regards
>> Geo
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> __________ Information from ESET Mail Security, version of virus
> signature database 14417 (20161109) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
__________ Information from ESET Mail Security, version of virus signature database 14419 (20161110) __________
http://www.eset.com
