[Qgis-developer] About QGIS-*.DMP files in Temp folder on Windows
Jonathan Moules jonathan-lists at lightpear.com
Wed Nov 9 12:37:01 PST 2016
Have you reported it to the bug tracker - https://hub.qgis.org/issues -
That's the best way to report this sort of behaviour. While I can see
why a dmp file would be useful, no program should be leaving GB of dump
files behind.
Maybe it should clean up when there are more than x number?
Cheers,
Jonathan
On 09/11/2016 11:28, Geo DrinX wrote:
> Good morning,
> purging my PC,  I found 1595  files named "qgis-*.dmp"  in my Temp
> folder.
> Totally, they amount to 36 giga of space  :(
> For example, I have many of:
> myUSER\AppData\Local\Temp\qgis-20140915-160805-11200-8480-c3a2817.dmp
> each of 23 mega.
> So, for each quitting of QGIS since 2.18  from september 05 2014  I
> had a crash (also without any plugin installed).
> Also, randomically I had crashes.
> So, now I am deleting these files, to have space sufficent in my PC to
> work.
> I hope this can be sufficient for you to start a good debug of this
> problem, that I have reported more than once.
> If you need, I can share that files with you (also if I don't know how).
> Best regards
> Geo
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161109/557d1b0d/attachment.html>
