[Qgis-developer] Changing ergonomy of the visibility of layers inside groups ?
Nyall Dawson nyall.dawson at gmail.com
Wed Nov 16 03:03:01 PST 2016
On 15 November 2016 at 20:34, Even Rouault <even.rouault at spatialys.com> wrote:
> Hi,
> I've been involved in discussions about improving/changing how visibility of
> layers (or groups) is handled when they are inside groups. Currently if you
> check/uncheck a group, this recursively checks/unchecks all its items (layers
> or sub-groups). There are workflows with large projects that include ~ 50
> layers in several groups and where users need to quicly turn on/off the
> visibility of groups, but when they don't want to change the visible of items
> inside the group. For those use cases, the layer themes functionnality has
> been tested but doesn't solve the need to be able to quickly (1 click) turn
> on/off/on/off the visibility of a group to be able to detect changes between
> raster imagery (the human eye is sensitive to movements more than colors), and
> they don't really have predefined configurations (would require creating tens of
> them)
> Basically what is proposed is the following:
> [ ] Group
>         [x] Layer 1   --> Layer checked but group is not --> invisible
>         [  ] Layer 2
> [x] Group
>         [x] Layer 1   --> Layer checked and group too --> visible
>         [  ] Layer 2
> There's a ticket https://hub.qgis.org/issues/14547 about that.
> In the ticket it is suggested that the current behaviour might be preserved by
> using control-click. Control-click on a group would check/uncheck recursively
> all sub-items.
> One effect of this change is that there wouldn't be anymore a tri-state for a
> group. It is either checked or unchecked. One potential downside of the new
> behaviour would be that it might not be immediately obvious to determine the
> visibility of a layer if you have several levels of hiearchy : looking only at
> the layer item if it is checked isn't sufficient to tell about its visibility.
> Not sure if that's an issue though (and if so what could be ways of indicating
> the visibility state)
> At the API level, from what I can see,
> * Qt::CheckState QgsLayerTreeGroup::isVisible() would be renamed to bool
> isChecked() since it would be a binary state and not related to visibility.
> I'm not sure if there are users outside of the layer tree mechanism where we
> really need to want if a group is visible (ie all its subgroups and layers are
> visible ?). Wouldn't be hard to implement anyway
> * Qt::CheckState QgsLayerTreeLayer::isVisible() would be "split" into a bool
> isChecked() and a bool isVisible(). The later would inspect recursively its
> parents to figure out the final visibility state.
> Thoughts ?
Sounds like a great usability improvement to me!
Nyall
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
