[Qgis-developer] Field Menu Range settings odd behaviour
roy roy
royroge at outlook.com
Thu Nov 17 02:36:21 PST 2016
working with field menu (QGIS 2.14.8 OSGEO4W64) i noted a behaviour that
i find misleading and
could potentially lead to severe errors in edit session:
say that i want to set a range for an integer field with
min value 1
max value 5
step 1
at this point i would expect that QGIS only accepts "1 2 3 4 5" and
throw an error if i insert 6
while editing; infact if i erroneously insert "6" QGIS will not complain
and happily save the
maximun value for range (i.e 5) i find this odd and a way to defeat the
hole pourpose of my
setting.
I think this is a bug, can anyone confirm? If this is the expected
behaviour i think the logic
of this tool is flawed because QGIS should not insert values at his own
will but should instead warn the
user that the value is outside the expected range.
Thanks, Roy.
