[Qgis-developer] Field Menu Range settings odd behaviour
roy roy royroge at outlook.com
Mon Nov 21 00:18:14 PST 2016
Hi:)
Anybody interest in this issue?
Il 17/11/2016 11:36, roy roy ha scritto:
> Hi,
> working with field menu (QGIS 2.14.8 OSGEO4W64) i noted a behaviour that
> i find misleading and
> could potentially lead to severe errors in edit session:
> say that i want to set a range for an integer field with
> min value 1
> max value 5
> step 1
> at this point i would expect that QGIS only accepts "1 2 3 4 5" and
> throw an error if i insert 6
> while editing; infact if i erroneously insert "6" QGIS will not complain
> and happily save the
> maximun value for range (i.e 5) i find this odd and a way to defeat the
> hole pourpose of my
> setting.
> I think this is a bug, can anyone confirm? If this is the expected
> behaviour i think the logic
> of this tool is flawed because QGIS should not insert values at his own
> will but should instead warn the
> user that the value is outside the expected range.
> Thanks, Roy.
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
