[Qgis-developer] Field Menu Range settings odd behaviour
Matthias Kuhn matthias at opengis.ch
Mon Nov 21 00:40:11 PST 2016
With QGIS 2.16 constraints have been introduced that are able to check
entered values and provide feedback as well as prevent the user from
clicking ok:
https://www.qgis.org/en/site/forusers/visualchangelog216/index.html#feature-constraints-on-widgets
All the best
Matthias
On 11/21/2016 09:18 AM, roy roy wrote:
> Hi:)
> Anybody interest in this issue?
> Il 17/11/2016 11:36, roy roy ha scritto:
>> Hi,
>> working with field menu (QGIS 2.14.8 OSGEO4W64) i noted a behaviour that
>> i find misleading and
>> could potentially lead to severe errors in edit session:
>> say that i want to set a range for an integer field with
>> min value 1
>> max value 5
>> step 1
>> at this point i would expect that QGIS only accepts "1 2 3 4 5" and
>> throw an error if i insert 6
>> while editing; infact if i erroneously insert "6" QGIS will not complain
>> and happily save the
>> maximun value for range (i.e 5) i find this odd and a way to defeat the
>> hole pourpose of my
>> setting.
>> I think this is a bug, can anyone confirm? If this is the expected
>> behaviour i think the logic
>> of this tool is flawed because QGIS should not insert values at his own
>> will but should instead warn the
>> user that the value is outside the expected range.
>> Thanks, Roy.
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
