[Qgis-developer] SAGA and TauDEM algs in QGIS from KingChaos package
William Kyngesburye
woklist at kyngchaos.com
Sun Nov 20 10:15:13 PST 2016
The version I bundle is 2.2.3, not 2.3.x, and is supported by Processing.
I get the segfault when I try, details tell me it's happening when SAGA tries to get the projection info from the file. I don't know how to fix this, and it's not a QGIS problem but a SAGA problem. I wonder if SAGA 2.2.x is not fully compatible with GDAL 2.1, I did see an initial item in the SAGA 2.2.0 changelog mentioning GDAL 2 compatibility that "was not complete", but no other changes in later versions specifically about improving GDAL 2 compatibility.
> On Nov 20, 2016, at 10:21 AM, Salvatore Larosa <lrssvtml at gmail.com> wrote:
> On Sun, Nov 20, 2016 at 4:13 PM, Sebastiaan Couwenberg
> <sebastic at xs4all.nl> wrote:
>> On 11/20/2016 04:11 PM, Salvatore Larosa wrote:
>>> I have installed 2.14.8 from William Kyngesburye's packages, all ok. I
>>> noticed that almost all the algs of SAGA and TauDEM do not work.
>> http://hub.qgis.org/issues/13279
>> SAGA changes its API too often, and QGIS has not been adapted to work
>> with the SAGA 2.3.x LTS releases yet.
> Thank you for your quick reply.
> The issue is a segfault here and OSX package (QGIS LTR 2.14.8) bundled
> with SAGA 2.2.3.
> Anyway I don't see a syntax command error as mentioned from the issue
> which seems was fixed, at least for the 2.2.x version.
> Best Regards,
> -SL
> Salvatore Larosa
> linkedIn: http://linkedin.com/in/larosasalvatore
> twitter: @lrssvt
> skype: s.larosa
> IRC: lrssvt on freenode
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
