[Qgis-developer] SAGA and TauDEM algs in QGIS from KingChaos package
Johan Van de Wauw johan.vandewauw at gmail.com
Sun Nov 20 12:04:46 PST 2016
Can you check if you have the same error when using saga_cmd without
using processing?
@William: Which compiler was used for saga on mac os x? We had an
issue with gcc6 - this looks similar. It is fixed in trunk and in
(upcoming) 2.3.2 release of SAA.
Kind Regards,
Johan
On Sun, Nov 20, 2016 at 7:15 PM, William Kyngesburye
<woklist at kyngchaos.com> wrote:
> The version I bundle is 2.2.3, not 2.3.x, and is supported by Processing.
> I get the segfault when I try, details tell me it's happening when SAGA tries to get the projection info from the file.  I don't know how to fix this, and it's not a QGIS problem but a SAGA problem.  I wonder if SAGA 2.2.x is not fully compatible with GDAL 2.1, I did see an initial item in the SAGA 2.2.0 changelog mentioning GDAL 2 compatibility that "was not complete", but no other changes in later versions specifically about improving GDAL 2 compatibility.
>> On Nov 20, 2016, at 10:21 AM, Salvatore Larosa <lrssvtml at gmail.com> wrote:
>> On Sun, Nov 20, 2016 at 4:13 PM, Sebastiaan Couwenberg
>> <sebastic at xs4all.nl> wrote:
>>> On 11/20/2016 04:11 PM, Salvatore Larosa wrote:
>>>> I have installed 2.14.8 from William Kyngesburye's packages, all ok. I
>>>> noticed that almost all the algs of SAGA and TauDEM do not work.
>>> http://hub.qgis.org/issues/13279
>>> SAGA changes its API too often, and QGIS has not been adapted to work
>>> with the SAGA 2.3.x LTS releases yet.
>> Thank you for your quick reply.
>> The issue is a segfault here and OSX package (QGIS LTR 2.14.8) bundled
>> with SAGA 2.2.3.
>> Anyway I don't see a syntax command error as mentioned from the issue
>> which seems was fixed, at least for the 2.2.x version.
>> Best Regards,
>> -SL
>> Salvatore Larosa
>> linkedIn: http://linkedin.com/in/larosasalvatore
>> twitter: @lrssvt
>> skype: s.larosa
>> IRC: lrssvt on freenode
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> Earth: "Mostly harmless"
> - revised entry in the HitchHiker's Guide to the Galaxy
