[Qgis-developer] SAGA and TauDEM algs in QGIS from KingChaos package
Salvatore Larosa
lrssvtml at gmail.com
Sun Nov 20 12:19:19 PST 2016
On Sun, Nov 20, 2016 at 9:04 PM, Johan Van de Wauw
<johan.vandewauw at gmail.com> wrote:
> Can you check if you have the same error when using saga_cmd without
> using processing?
I also tried saga_cmd from shell with the following command:
saga_cmd io_gdal 0 -TRANSFORM 1 -INTERPOL 0 -GRIDS
"/Users/slarosa/MU/elevationutm.sgrd" -FILES
"/Users/slarosa/MU/elevation_utm.tif"
and it throws:
21:15:02: Error: Failed to get the working directory (error 2: No such
file or directory)
____________________________
library path: /Applications/QGIS.app/Contents/MacOS/lib/saga/
library name: libio_gdal
library : GDAL/OGR
tool : Import Raster
author : O.Conrad (c) 2007 (A.Ringeler)
Parameters
Grids: No objects
Files: "/Users/slarosa/MU/elevation_utm.tif"
Transformation: yes
Interpolation: Nearest Neighbor
loading: /Users/slarosa/MU/elevation_utm.tif
Driver: GTiff
Bands: 1
Rows: 857
Columns: 581
Transformation:
x' = 592364.913689 + x * 19.998468 + y * 0.000000
y' = 4366938.815080 + x * 0.000000 + y * -20.010110
loading band [1/1]
Segmentation fault: 11
Salvatore Larosa
linkedIn: http://linkedin.com/in/larosasalvatore
twitter: @lrssvt
skype: s.larosa
IRC: lrssvt on freenode
