[Qgis-developer] SAGA and TauDEM algs in QGIS from KingChaos package
William Kyngesburye
woklist at kyngchaos.com
Sun Nov 20 18:25:36 PST 2016
On Nov 20, 2016, at 2:19 PM, Salvatore Larosa <lrssvtml at gmail.com> wrote:
> On Sun, Nov 20, 2016 at 9:04 PM, Johan Van de Wauw
> <johan.vandewauw at gmail.com> wrote:
>> Can you check if you have the same error when using saga_cmd without
>> using processing?
> I also tried saga_cmd from shell with the following command:
> saga_cmd io_gdal 0 -TRANSFORM 1 -INTERPOL 0 -GRIDS
> "/Users/slarosa/MU/elevationutm.sgrd" -FILES
> "/Users/slarosa/MU/elevation_utm.tif"
> and it throws:
> 21:15:02: Error: Failed to get the working directory (error 2: No such
> file or directory)
I don't get a directory error, but it does say "Grids: No objects".
> On Nov 20, 2016, at 2:04 PM, Johan Van de Wauw <johan.vandewauw at gmail.com> wrote:
> @William: Which compiler was used for saga on mac os x? We had an
> issue with gcc6 - this looks similar. It is fixed in trunk and in
> (upcoming) 2.3.2 release of SAA.
I'm using Clang 7.0.2 from Xcode 7.2. Is the fix something that can be backported to 2.2? QGIS doesn't support 2.3+ yet.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Oh, look, I seem to have fallen down a deep, dark hole. Now what does that remind me of? Ah, yes - life."
- Marvin
