[Qgis-developer] qgis server - wms - strange circles
Marco Bernasocchi
marco at opengis.ch
Sun Nov 27 09:09:11 PST 2016
Hi Martin sounds very similar to [1]
Though it was on old qgis versions. Have you double checked that you maybe have an old version of the server running?
I wonder if Matthias (in cc) has an idea
[1] http://gis.stackexchange.com/questions/143997/strange-circles-have-appeared-on-qgis-map
On 28 November 2016 04:56:08 GMT+13:00, Martin Landa <landa.martin at gmail.com> wrote:
>Hi,
>I am having problem with QGIS Server (2.14.8) which shows strange
>circles (see attachment) when publishing data as WMS. The project is
>prepared using same QGIS version. When I remove manually
> <SingleCategoryDiagramRenderer diagramType="Pie">
> <DiagramCategory penColor="#000000"
>labelPlacementMethod="XHeight" penWidth="0" diagramOrientation="Up"
>minimumSize="0" barWidth="5" penAlpha="255"
>maxScaleDenominator="1e+08" backg\
>roundColor="#ffffff" transparency="0" width="15"
>scaleDependency="Area" backgroundAlpha="255" angleOffset="1440"
>scaleBasedVisibility="0" enabled="0" height="15" sizeType="MM"
>minScaleDenom\
>inator="0">
> <fontProperties description="Droid
>Sans,10,-1,5,50,0,0,0,0,0" style=""/>
> </DiagramCategory>
> </SingleCategoryDiagramRenderer>
> <DiagramLayerSettings yPosColumn="-1" linePlacementFlags="10"
>placement="0" dist="0" xPosColumn="-1" priority="0" obstacle="0"
>zIndex="0" showAll="1"/>
>from the project, the circles disappears. Any idea what could be
>wrong? I have diagram disabled in the project. QGIS desktop renders
>data as expected. Thanks, Martin
>Martin Landa
>http://geo.fsv.cvut.cz/gwiki/Landa
>http://gismentors.cz/mentors/landa
>_______________________________________________
>Qgis-developer mailing list
>Qgis-developer at lists.osgeo.org
>List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Marco Bernasocchi (mobile).
OPENGIS.ch - berna.io - 27summits.ch
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161128/6af441f5/attachment.html>
