[Qgis-developer] qgis server - wms - strange circles
Tim Sutton
tim at kartoza.com
Sun Nov 27 10:13:46 PST 2016
Hi
Just disable diagrams on the offending layer properties. The circles get added if you open a project using a newer version of QGIS then an older e.g. 2.14 LTR.
Regards
Tim
Tim Sutton
Co-founder of Kartoza
QGIS project chairman
> On 27 Nov 2016, at 7:09 PM, Marco Bernasocchi <marco at opengis.ch> wrote:
> Hi Martin sounds very similar to [1]
> Though it was on old qgis versions. Have you double checked that you maybe have an old version of the server running?
> I wonder if Matthias (in cc) has an idea
> [1] http://gis.stackexchange.com/questions/143997/strange-circles-have-appeared-on-qgis-map
>> On 28 November 2016 04:56:08 GMT+13:00, Martin Landa <landa.martin at gmail.com> wrote:
>> Hi,
>> I am having problem with QGIS Server (2.14.8) which shows strange
>> circles (see attachment) when publishing data as WMS. The project is
>> prepared using same QGIS version. When I remove manually
>> <SingleCategoryDiagramRenderer diagramType="Pie">
>> <DiagramCategory penColor="#000000"
>> labelPlacementMethod="XHeight" penWidth="0" diagramOrientation="Up"
>> minimumSize="0" barWidth="5" penAlpha="255"
>> maxScaleDenominator="1e+08" backg\
>> roundColor="#ffffff" transparency="0" width="15"
>> scaleDependency="Area" backgroundAlpha="255" angleOffset="1440"
>> scaleBasedVisibility="0" enabled="0" height="15" sizeType="MM"
>> minScaleDenom\
>> inator="0">
>> <fontProperties description="Droid
>> Sans,10,-1,5,50,0,0,0,0,0" style=""/>
>> </DiagramCategory>
>> </SingleCategoryDiagramRenderer>
>> <DiagramLayerSettings
>> yPosColumn="-1" linePlacementFlags="10"
>> placement="0" dist="0" xPosColumn="-1" priority="0" obstacle="0"
>> zIndex="0" showAll="1"/>
>> from the project, the circles disappears. Any idea what could be
>> wrong? I have diagram disabled in the project. QGIS desktop renders
>> data as expected. Thanks, Martin
> Marco Bernasocchi (mobile).
> OPENGIS.ch - berna.io - 27summits.ch
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161127/2655c20a/attachment-0001.html>
