[Qgis-developer] Fwd: Re: [Geopackage] Geopackage on a shared network drive
Nyall Dawson
nyall.dawson at gmail.com
Mon Oct 3 02:08:14 PDT 2016
On 3 October 2016 at 18:33, Neumann, Andreas <a.neumann at carto.net> wrote:
> Hi Even,
> Thank you for sharing this finding!
> In that case I think that QGIS should offer a flag to open Geopackages in
> read-only mode.
> Even - since you are "Mr. Geopackage" in the QGIS project anyway - can you
> please make sure that this can be covered in the upcoming Geopackage
> improvements? Would a "read-only" mode also be useful for other data
> formats? I opened a ticket at http://hub.qgis.org/issues/15652 and assigned
> it to you. I have no idea how much effort this enhancement would mean - can
> you please do an estimate and send me a quote for that? Maybe we could still
> include it in the upcoming Geopackage improvements financed by the Swiss
> QGIS user group.
There's the "read only" setting (hidden away) under Project Properties
-> Identify Layers which this could potentially hook into.
Nyall
> This also leads to a follow up question: many OGR data formats have "open
> options". As far as I know, these options are not exposed to the User in
> QGIS, other than the encoding - or did I miss something? Should we introduce
> a "GUI" way in QGIS 3.x to expose these "open options" in the "add vector
> layer" dialogue?
> Thanks,
> Andreas
> On 2016-10-01 23:38, Even Rouault wrote:
> FYI: An interesting finding to improve performance of large Geopackage on a
> shared network drive.
> ---------- Message transmis ----------
> Sujet : Re: [Geopackage] Geopackage on a shared network drive
> Date : samedi 01 octobre 2016, 16:41:05
> De : Árni Geirsson via Geopackage <geopackage at lists.opengeospatial.org>
> À : Even Rouault <even.rouault at spatialys.com>
> CC : geopackage at lists.opengeospatial.org
> Yes! It renders very quickly after I set the read-only flag in the file
> explorer.
> That goes a long way towards solving the problem for me because as I
> mentioned, the team would like to use this format to store geodata, not to
> edit it and certainly not to make edits by multiple concurrent users.
> Thank you so much for your help!
> Árni
> Árni Geirsson
> *Alta ehf* // +354 582 5000 // +354 897 9549
> www.alta.is // Alta á Twitter <http://twitter.com/alta_ehf> // Alta á
> Facebook <http://www.facebook.com/pages/Alta/161795813838691?v=wall>
> Gæða- og umhverfisstefna Alta <http://alta.is/pdf/svonavinnumvid.pdf>
> On 1 October 2016 at 14:28, Even Rouault <even.rouault at spatialys.com> wrote:
> Le samedi 01 octobre 2016 16:02:38, Árni Geirsson a écrit :
> Hello Even
> Thank you for your suggestion. I made the changes you suggested, adding
> set SQLITE_USE_OGR_VFS=YES
> after
> set VSI_CACHE=TRUE
> set VSI_CACHE_SIZE=1000000
> but there was no difference. Was this perhaps not the right way to do it?
> Yes, that's correct.
> Hum actually reviewing the code, the cache mechanism is only enabled when
> the
> file is opened in read-only mode, whereas QGIS will open the file in
> read-write
> mode.
> You could perhaps try to make the GPKG read-only in the explorer?, at least
> just to test if it is a promising optimization. I guess write support for
> the
> cache mechanism could be added.
> A drawback of a cache machnism is that it would defeat the updates in
> SQLite
> to deal with concurrent editing, but anyway such mechanisms don't work very
> well on network shares.
> Anyway, I would think that I am not alone in seeing this as a problem
> but I
> find very little about it on the web.
> Árni
> Árni Geirsson
> On 30 September 2016 at 19:52, Even Rouault <even.rouault at spatialys.com>
> wrote:
> Le vendredi 30 septembre 2016 00:44:45, Árni Geirsson via Geopackage a
> écrit :
> Dear Geopackage developers!
> I look forward to the day when Geopackage replaces the old shapefiles
> and I
> thank you for your efforts. As a user in a small team that uses QGIS
> and shares data on a NAS box, basically a Samba server for network
> shares, I notice that Geopackage data loads very slowly, much more
> slowly than a shapefile stored in exactly the same shared folder. I
> have noticed this with Spatialite, too, and suspect that the problem
> lies with Sqlite and some problem it has with the networking
> protocol.
> Since Geopackage is intended (as I understand) as a storage and
> exchange format for geodata, rather than a general purpose database
> format like Spatialite, I was
> hoping
> that this problem could be overcome and that the Geopackage data
> would
> load
> as fast as the shapefile data from the network share. When the
> Geopackage and shapefile data are both on a local drive, I see no
> difference in the loading speed.
> Do you think this will be solved?
> QGIS tweaks GDAL/OGR to use a large buffer size to speed up network
> access to
> shapefiles (or any format that uses the GDAL I/O layer, which is called
> "VSI").
> If you look at the qgis.bat in c:\osgeo4w\bin, you will see :
> set VSI_CACHE=TRUE
> But by default, the OGR GPKG driver uses SQLite own I/O layer, which
> probably
> does access with a granualrity of a SQLite page size (4KBytes). You
> could
> tried to define the
> SQLITE_USE_OGR_VFS=YES environmenet variable, restart QGIS and then
> SQLite should use the GDAL/OGR I/O layer and hopefully benefit from the
> buffering. I
> have not tried that, so not completely sure if it will improve things.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
