[Qgis-developer] PyQgsServerWFST disabled on Travis
Alessandro Pasotti
apasotti at gmail.com
Mon Oct 3 02:11:27 PDT 2016
On Mon, Oct 3, 2016 at 10:44 AM, Matthias Kuhn <matthias at opengis.ch> wrote:
> Following the conversation from
> https://github.com/qgis/QGIS/commit/89d4998 , this is an announcement
> to notify that the PyQgsServerWFST has been disabled on the Travis builds.
> Work has been underway to remove "noisy" tests from Travis which cause
> false alarms and these tests regularly fail for unrelated changes.
> False alarms are bad as they undermine confidence in the CI results
> and encourage contributors to ignore the test results.
> If you're interested in seeing these tests continue as part of the CI
> infrastructure here are some examples of typical random failures these
> tests encounter:
> PyQgsServerWFST: https://travis-ci.org/qgis/QGIS/builds/164559513
> Matthias
Hi Matthias,
Is there any way to see the complete build logs for that particular build?
I'm trying with dash but the interesting part was apparently cut.
The rest of the test output was removed since it exceeds the threshold
of 307200 bytes.
Alessandro Pasotti
w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161003/45e0e079/attachment.html>
