[Qgis-developer] PyQgsServerWFST disabled on Travis
Nyall Dawson
nyall.dawson at gmail.com
Mon Oct 3 02:28:52 PDT 2016
On 3 October 2016 at 19:11, Alessandro Pasotti <apasotti at gmail.com> wrote:
> On Mon, Oct 3, 2016 at 10:44 AM, Matthias Kuhn <matthias at opengis.ch> wrote:
>> Following the conversation from
>> https://github.com/qgis/QGIS/commit/89d4998 , this is an announcement
>> to notify that the PyQgsServerWFST has been disabled on the Travis builds.
>> Work has been underway to remove "noisy" tests from Travis which cause
>> false alarms and these tests regularly fail for unrelated changes.
>> False alarms are bad as they undermine confidence in the CI results
>> and encourage contributors to ignore the test results.
>> If you're interested in seeing these tests continue as part of the CI
>> infrastructure here are some examples of typical random failures these
>> tests encounter:
>> PyQgsServerWFST: https://travis-ci.org/qgis/QGIS/builds/164559513
>> Matthias
> Hi Matthias,
> Is there any way to see the complete build logs for that particular build?
> I'm trying with dash but the interesting part was apparently cut.
> The rest of the test output was removed since it exceeds the threshold of
> 307200 bytes.
If you make the very first output from the test a 'CTEST_FULL_OUTPUT'
line, then the truncation doesn't occur.
test_qgsserver_accesscontrol.py uses this, have a look how it's done there.
Nyall
> Alessandro Pasotti
> w3: www.itopen.it
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
