[Qgis-developer] QGIS D3 DataVis Plugin Status Report
matteo
matteo.ghetta at gmail.com
Mon Oct 3 02:34:36 PDT 2016
Hi Calvin,
I had some time to deepen in the list of D3 libraries you have listen:
> 1. *d3pie* (http://d3pie.org/) - This is a very attractive pie chart and
> I like it, but it has only 7 contributors on GitHub and seems to be
> stagnant.
if I understand it well, this allows just the pie plottin
> 2. *D3Plus* (http://d3plus.org/) - Has a number of reusable components -
> 19 contributors on GitHub.
seems very very good.. do you need to understand some external
component? I did not (but maybe I have them already installed) and I was
able to save a custom html interactive plot
> 3. *NVD3* (http://nvd3.org/) - Lots of reusable components - 200
I like it too..
> 4. *C3* (http://c3js.org/) - Also a number of components - 88
> contributors, but there haven't been any updates for over a year.
seems less customizable than the others..
IMHO what I plot plugin like that one we are trying to understand how to
build should have some mandatory capabilities:
1. callback from plot to QGIS map canvas. So clicking on the
point/bar/boxplot should give a signal that can be used to
select/zooming/whatever in QGIS
2. plots should be callable from Processing
3. it could be really good to be able to embed plots in the print
composer too
I don't know if all these is possible, but maybe it is worth to try
Cheers
Matteo
