[Qgis-developer] PyQgsServerWFST disabled on Travis
Matthias Kuhn matthias at opengis.ch
Mon Oct 3 03:11:00 PDT 2016
On 10/03/2016 12:04 PM, Alessandro Pasotti wrote:
> On Mon, Oct 3, 2016 at 11:28 AM, Nyall Dawson <nyall.dawson at gmail.com
> <mailto:nyall.dawson at gmail.com>> wrote:
>     On 3 October 2016 at 19:11, Alessandro Pasotti <apasotti at gmail.com
>     <mailto:apasotti at gmail.com>> wrote:
>     > On Mon, Oct 3, 2016 at 10:44 AM, Matthias Kuhn <matthias at opengis.ch <mailto:matthias at opengis.ch>> wrote:
>     >> Following the conversation from
>     >> https://github.com/qgis/QGIS/commit/89d4998
>     <https://github.com/qgis/QGIS/commit/89d4998> , this is an announcement
>     >> to notify that the PyQgsServerWFST has been disabled on the Travis builds.
>     >> Work has been underway to remove "noisy" tests from Travis which cause
>     >> false alarms and these tests regularly fail for unrelated changes.
>     >> False alarms are bad as they undermine confidence in the CI results
>     >> and encourage contributors to ignore the test results.
>     >> If you're interested in seeing these tests continue as part of the CI
>     >> infrastructure here are some examples of typical random failures these
>     >> tests encounter:
>     >> PyQgsServerWFST: https://travis-ci.org/qgis/QGIS/builds/164559513
>     <https://travis-ci.org/qgis/QGIS/builds/164559513>
>     >> Matthias
>     > Hi Matthias,
>     > Is there any way to see the complete build logs for that particular build?
>     > I'm trying with dash but the interesting part was apparently cut.
>     > The rest of the test output was removed since it exceeds the threshold of
>     > 307200 bytes.
>     If you make the very first output from the test a 'CTEST_FULL_OUTPUT'
>     line, then the truncation doesn't occur.
>     test_qgsserver_accesscontrol.py uses this, have a look how it's done
>     there.
>     Nyall
> Thanks! I will do it.
> BTW, restarting the build
> https://travis-ci.org/qgis/QGIS/builds/164559513, the WFS-T test now
> passes but there is another one that fails:
> PyQgsComposerPicture ....................***Timeout 60.00 sec
> Should we disable that one too?
It's already disabled, the regex for blacklisting was broken and it was
executed by mistake.
Fixed in 8e54acf
Matthias
> Alessandro Pasotti
> w3:   www.itopen.it <http://www.itopen.it>
