[Qgis-developer] PyQgsServerWFST disabled on Travis
Alessandro Pasotti
apasotti at gmail.com
Mon Oct 3 07:43:20 PDT 2016
On Mon, Oct 3, 2016 at 12:11 PM, Matthias Kuhn <matthias at opengis.ch> wrote:
> On 10/03/2016 12:04 PM, Alessandro Pasotti wrote:
> > On Mon, Oct 3, 2016 at 11:28 AM, Nyall Dawson <nyall.dawson at gmail.com
> > <mailto:nyall.dawson at gmail.com>> wrote:
> > On 3 October 2016 at 19:11, Alessandro Pasotti <apasotti at gmail.com
> > <mailto:apasotti at gmail.com>> wrote:
> > > On Mon, Oct 3, 2016 at 10:44 AM, Matthias Kuhn <
> matthias at opengis.ch <mailto:matthias at opengis.ch>> wrote:
> > >> Following the conversation from
> > >> https://github.com/qgis/QGIS/commit/89d4998
> > <https://github.com/qgis/QGIS/commit/89d4998> , this is an
> announcement
> > >> to notify that the PyQgsServerWFST has been disabled on the
> Travis builds.
> > >> Work has been underway to remove "noisy" tests from Travis which
> cause
> > >> false alarms and these tests regularly fail for unrelated changes.
> > >> False alarms are bad as they undermine confidence in the CI
> results
> > >> and encourage contributors to ignore the test results.
> > >> If you're interested in seeing these tests continue as part of
> the CI
> > >> infrastructure here are some examples of typical random failures
> these
> > >> tests encounter:
> > >> PyQgsServerWFST: https://travis-ci.org/qgis/QGIS/builds/164559513
> > <https://travis-ci.org/qgis/QGIS/builds/164559513>
> > >> Matthias
> > > Hi Matthias,
> > > Is there any way to see the complete build logs for that
> particular build?
> > > I'm trying with dash but the interesting part was apparently cut.
> > > The rest of the test output was removed since it exceeds the
> threshold of
> > > 307200 bytes.
> > If you make the very first output from the test a 'CTEST_FULL_OUTPUT'
> > line, then the truncation doesn't occur.
> > test_qgsserver_accesscontrol.py uses this, have a look how it's done
> > there.
> > Nyall
> > Thanks! I will do it.
> > BTW, restarting the build
> > https://travis-ci.org/qgis/QGIS/builds/164559513, the WFS-T test now
> > passes but there is another one that fails:
> > PyQgsComposerPicture ....................***Timeout 60.00 sec
> > Should we disable that one too?
> It's already disabled, the regex for blacklisting was broken and it was
> executed by mistake.
> Fixed in 8e54acf
> Matthias
I cannot see any other reason for the random failures than the "sleep(x)"
that the test waited for the server to accept connections.
I've changed the check to a more robust wait-until-ready-or-timeout
function, this should eliminate those odd sparse failures.
Please let me know if you still have problems with these tests.
https://github.com/qgis/QGIS/pull/3563
Alessandro Pasotti
w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161003/8e534816/attachment-0001.html>
