[Qgis-developer] Questions around xyz tile server connections in master 2
Neumann, Andreas
a.neumann at carto.net
Tue Oct 4 00:48:22 PDT 2016
I have a couple of questions around the new "Tileserver" layer support
in QGIS desktop to be released with 2.18. I think the main commit is
https://github.com/qgis/QGIS/commit/f5b657db19eda7e72e6ed34eb7fe333c156acad0
- right?
First, let me thank you a lot for this - Martin and Lutra Consulting
for developing/sponsoring it!
However, I wonder if the usability of the newly added tilserver is
already good enough? Or at least I think it is not really obvious how to
use it.
1. How can add a new connection to a tile server? Is the browser the
only way? If yes, I hope that an additional entry to Layer --> Add Layer
menu could be added - all other layer types can be added this way.
2. What is a correct URL? This is really hard to find out. F.e. I went
to http://wiki.openstreetmap.org/wiki/Tile_servers and tried to copy
some URLs and failed about finding the correct syntax. I added the layer
to the project --> nothing happened. No display, no error message. Maybe
because the projections do not match? - or would QGIS reproject on the
fly?
3. Can we add some popular tile map server URLs by default - similar to
the QuickMapServices plugin?
4. How can one edit an existing tile server connection - e.b. change
title or URL? Currently, one can only delete and re-add it.
Thank you for your reply,
Andreas
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161004/ec8a6736/attachment.html>
