[Qgis-developer] Questions around xyz tile server connections in master 2
Neumann, Andreas
a.neumann at carto.net
Tue Oct 4 01:32:30 PDT 2016
So I found out that http://tile.openstreetmap.org/{z}/{x}/{y}.png seems
to work.
However, if I add this OSM layer to my Swiss QGIS project (EPSG:21781) -
the swiss data seems to appear in the atlantic, west of "Guinea
Ecuatorial" ;-(
Andreas
On 2016-10-04 09:48, Neumann, Andreas wrote:
> Hi,
> I have a couple of questions around the new "Tileserver" layer support in QGIS desktop to be released with 2.18. I think the main commit is https://github.com/qgis/QGIS/commit/f5b657db19eda7e72e6ed34eb7fe333c156acad0 - right?
> First, let me thank you a lot for this - Martin and Lutra Consulting for developing/sponsoring it!
> However, I wonder if the usability of the newly added tilserver is already good enough? Or at least I think it is not really obvious how to use it.
> 1. How can add a new connection to a tile server? Is the browser the only way? If yes, I hope that an additional entry to Layer --> Add Layer menu could be added - all other layer types can be added this way.
> 2. What is a correct URL? This is really hard to find out. F.e. I went to http://wiki.openstreetmap.org/wiki/Tile_servers and tried to copy some URLs and failed about finding the correct syntax. I added the layer to the project --> nothing happened. No display, no error message. Maybe because the projections do not match? - or would QGIS reproject on the fly?
> 3. Can we add some popular tile map server URLs by default - similar to the QuickMapServices plugin?
> 4. How can one edit an existing tile server connection - e.b. change title or URL? Currently, one can only delete and re-add it.
> Thank you for your reply,
> Andreas
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161004/fa7d2545/attachment.html>
