[Qgis-developer] Show Geotagged Images on Map
kimaidou
kimaidou at gmail.com
Mon Oct 10 00:50:30 PDT 2016
Sorry, my previous message was a bit "dry". Here are the steps:
* Open the vector layer properties dialog
* Go to the Style tab
* Use "Single symbol renderer"
* Choose "SVG Symbol"
* In the text input with the path to SVG, instead of using the "..." button
to choose a file, click instead of the button right next to it, to be able
to enter an expression. Choose "Edit"
* It opens a new dialog, with 2 tabs : Expression and Function editor ->
Go to the latest "Function editor" tab.
* You can here create a "New file" via the button at the top
* Then choose a name, and then you can copy/paste the whole text you found
in the URL https://gist.github.com/mdouchin/d66191ccfadd74cff3f0
* Then you can go back to the first tab "Expression", and use an expression
such as
show_picture( "picture_path_fieldname" )
where "picture_path_filename" is the name of the field containing the path
to the image for each feature. (you can have absolute path, or better,
paths relative to the QGIS project)
This is a bit cumbersome, but should work :)
Regards,
Michaël
2016-10-06 14:41 GMT+02:00 Joshua Quesenberry <engnfrc at gmail.com>:
> Hi Michaël,
> Sorry, I missed your reply when it originally came through. Can you
> elaborate further on how to use the code snippet? I’m only very vaguely
> following what you’re saying to do so far.
> Separately, would it be possible to add an image type to the symbol editor
> for shapefiles, etc. that can use the an equation to create the image name
> and then display the image from there?
> Thanks,
> JQ
> *From:* kimaidou [mailto:kimaidou at gmail.com]
> *Sent:* Monday, September 19, 2016 3:11 AM
> *To:* Joshua Quesenberry <engnfrc at gmail.com>
> *Cc:* qgis-developer <qgis-developer at lists.osgeo.org>
> *Subject:* Re: [Qgis-developer] Show Geotagged Images on Map
> Hi, you could use this snippets :
> Basically, it loads an image for each feature in a SVG, which can then be
> used as a symbol.
> Regards
> Michaël
> 2016-09-18 22:35 GMT+02:00 Joshua Quesenberry <engnfrc at gmail.com>:
> All,
> I was wondering if anyone knows of a current method for displaying
> geotagged images (or maybe just a thumbnail) directly on the map canvas
> without having to click on one image a time? I saw this thread, but the
> solution seems to be deprecated now: http://osgeo-org.1560.x6.
> nabble.com/Showing-thumbnails-of-geotagged-photos-td5008632.html
> Thanks,
> JQ
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161010/f9c6ee9b/attachment-0001.html>
