[Qgis-developer] Show Geotagged Images on Map
Joshua Quesenberry engnfrc at gmail.com
Thu Oct 6 05:41:13 PDT 2016
Hi Michaël,
Sorry, I missed your reply when it originally came through. Can you elaborate further on how to use the code snippet? I’m only very vaguely following what you’re saying to do so far.
Separately, would it be possible to add an image type to the symbol editor for shapefiles, etc. that can use the an equation to create the image name and then display the image from there?
Thanks,
JQ
Sent: Monday, September 19, 2016 3:11 AM
To: Joshua Quesenberry <engnfrc at gmail.com>
Cc: qgis-developer <qgis-developer at lists.osgeo.org>
Subject: Re: [Qgis-developer] Show Geotagged Images on Map
​Hi, you could use this snippets :
https://gist.github.com/mdouchin/d66191ccfadd74cff3f0
Basically, it loads an image for each feature in a SVG, which can then be used as a symbol.
Regards
Michaël
2016-09-18 22:35 GMT+02:00 Joshua Quesenberry <engnfrc at gmail.com <mailto:engnfrc at gmail.com> >:
All,
I was wondering if anyone knows of a current method for displaying geotagged images (or maybe just a thumbnail) directly on the map canvas without having to click on one image a time? I saw this thread, but the solution seems to be deprecated now: http://osgeo-org.1560.x6.nabble.com/Showing-thumbnails-of-geotagged-photos-td5008632.html
Thanks,
JQ
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161006/67295a1e/attachment-0001.html>
