[Qgis-developer] $scale vs. @map_scale variable - Inconsistency between Desktop and Server
Nyall Dawson nyall.dawson at gmail.com
Tue Oct 11 01:31:31 PDT 2016
On 11 Oct 2016 6:12 PM, "Neumann, Andreas" <a.neumann at carto.net> wrote:
> Hi Nyall,
> Thank you - this explains it. I wasn't aware that QGIS server uses an old
map renderer. I did not even know that different map renderers exist. But
this has nothing to do with the old vs. the new symbology - right? Because
QGIS Server seems to work just fine with the new symbology and labeling.
> So much work to do around QGIS 3.x / QGIS Server, etc. ...
Yes, it still uses the pre-multithreaded renderer. There's a work in
progress PR here fixing it:
https://github.com/qgis/QGIS/pull/3129
Nyall
> Andreas
> On 2016-10-11 10:05, Nyall Dawson wrote:
>> On 11 Oct 2016 5:59 PM, "Neumann, Andreas" <a.neumann at carto.net> wrote:
>> > Hi,
>> > I noticed that $scale and @map_scale exist in parallel, but are not
consistently behaving between QGIS Desktop and QGIS server.
>> > $scale: works fine on both Desktop and Server, but expression preview
in QGIS Desktop fails.
>> > @map_scale: works fine on QGIS Desktop and also in expression preview,
but fails on QGIS Server.
>> Hi Andreas,
>> Server doesn't have access to any of the map settings related variables,
like the scale, rotation, extent, etc. (This is why 25d ordering is messed
up in server).
>> Server needs to be ported away from the old map renderer before this can
be fixed.
>> Nyall
>> > Context: expression to calculate letter spacing in a label for
different map scale. Tested on QGIS Master 2.x on Windows 7 64bit.
>> > Thank you,
>> > Andreas
>> > _______________________________________________
>> > Qgis-developer mailing list
>> > Qgis-developer at lists.osgeo.org
>> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161011/c870b6be/attachment.html>
