[Qgis-developer] QgsField::length semantic
Sandro Santilli
strk at kbt.io
Tue Oct 11 03:21:31 PDT 2016
On Tue, Oct 11, 2016 at 12:11:06PM +0200, Even Rouault wrote:
> > According to this:
> > http://devzone.advantagedatabase.com/dz/webhelp/advantage9.0/server1/dbf_fi
> > eld_types_and_specifications.htm
> > A DBF field with extended data type "double" does not affect the
> > precision of the stored data, and the length information is simply
> > ignored.
> I had never seen such "double" type in use in .dbf, and it is certainly not
> handled by shapelib/OGR, and I have never seen reports that other shapefile
> producing software generate such field types. Might be a "Visual FoxPro"
> specific thing.
So what are those OFTReal types coming from ?
According to shapelib, the test shapefile field type is:
Field shape_area is an FTDouble with width 19 and precision 11
> > After all, a "Double" in a DBF is just 8 bytes anyway, so why bother
> > attempting to go beyond that ? Qgis is storing values in a Double too,
> > and the only reason I see to support "numeric" is storing arbitrary
> > precision values, which don't seem to be supported by OGR:
> > http://www.gdal.org/ogr__core_8h.html#a787194bea637faf12d61643124a7c9fc
> True, OGR ends up storing numeric fields as C double. The width/precision is
> mostly informative (and occasionnaly indeed an annoyance when backends start
> using it...)
Ok so my proposed fix for issue 15188 is simply to revert
the PR, which is the one making (mis)use of that information
while writing in the database.
--strk;
