[Qgis-developer] ogrLayerName in processing/tools/vector.py
Mark Johnson mj10777 at googlemail.com
Mon Oct 17 05:27:16 PDT 2016
At present, this is not so simple due to recent changes in gdal, but also
to changes made to support duplicate layer-names only layerid is being used.
For QGIS compiled against gdal 1.*
using: |layerid=n|layername=somename
should be used and in most cases work correctly.
At the moment an attempt to to open with 'layername' will first be
attempted (without checks for duplicate names, thus the first will be
taken) and if that fails, to open with layerid.
When gdal 2.* is being used, retrieving with layerid will fail after the
first table that has more than 1 geometry.
The goal of the Grant Programme '9)​  Correction of QgsOgrProvider
implementaion of GDAL 2.0' was to resolve this problem.
Mark Johnson
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161017/cac9d6bd/attachment.html>
