[Qgis-developer] Newbie question re: Qt, PyQt on MAC Yosemite, Sierra
Chris Nicholas
cnicholas at housecanary.com
Mon Oct 17 14:43:20 PDT 2016
loaded up QGIS 2.14 ‘Essen’ got all psyched to dive in and do a plugin, and seem to be hitting a brick wall…
From what I understand, you must use PyQt4, unless you compile EVERYTHING from source with Qt5 …
soo… thought I would just use an older Qt version… WRONG ! the installer says it is incompatible with this version of OS X ..
so… thought I would compile the Qt4 sources from scratch … WRONG! as per:
https://bugreports.qt.io/browse/QTBUG-48079 <https://bugreports.qt.io/browse/QTBUG-48079>
so…. um …. am I outta luck?
advice/condolences/RTFMs welcomed
thanks in advance!
Chris
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161017/1b82c5a3/attachment.html>
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161017/1b82c5a3/attachment.sig>
