[Qgis-developer] Newbie question re: Qt, PyQt on MAC Yosemite, Sierra
William Kyngesburye
woklist at kyngchaos.com
Mon Oct 17 18:30:55 PDT 2016
Are you using my package or trying to compile from source?
My package has everything needed in the app - Qt4 & PyQt4.
QGIS 2 is not completely ready for Qt5, so yes you need to use Qt4. Does the Qt4 installer refuse to install on your system, or just give a warning? I've never heard of it refusing to install. It should still work as long as you use a system SDK. I compile QGIS on Yosemite, but using an old Mt Lion SDK.
> On Oct 17, 2016, at 4:43 PM, Chris Nicholas <cnicholas at housecanary.com> wrote:
> loaded up QGIS 2.14 ‘Essen’ got all psyched to dive in and do a plugin, and seem to be hitting a brick wall…
> From what I understand, you must use PyQt4, unless you compile EVERYTHING from source with Qt5 …
> soo… thought I would just use an older Qt version… WRONG ! the installer says it is incompatible with this version of OS X ..
> so… thought I would compile the Qt4 sources from scratch … WRONG! as per:
> https://bugreports.qt.io/browse/QTBUG-48079
> so…. um …. am I outta luck?
> advice/condolences/RTFMs welcomed
> thanks in advance!
> Chris
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
All generalizations are dangerous, even this one.
