[Qgis-developer] Backport of master feature in QGIS 2.18
Jürgen E. Fischer
jef at norbit.de
Mon Oct 17 17:02:43 PDT 2016
Hi Even,
On Thu, 13. Oct 2016 at 12:18:38 +0200, Even Rouault wrote:
> - this PR adds new strings to translate (the DBManager changes might also).
> Will translators do another round of translations for 2.18.x ? If not, this
> might not be material appropriate for 2.18.x
Transifex is already target for QGIS3 (as it sticked with master). For
master_2, we talked about returning to the old scheme (ie.
scripts/update_ts_files.sh and committing language update individual).
> - as we are in 2.18.0 feature freeze, must I wait for 2.18.0 to be released
> before backporting (depending on previous question) ?
When we decided on the time frame for 2.18 in Bonn, we also decided that you
can add your geopackage improvements into 2.18.1 and I can add DWG support once
it ready - regardless of the feature freeze that normally applies to releases.
IMHO it shouldn't be applied now before 2.18 is released.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161018/228ec9e3/attachment.sig>
