[Qgis-developer] Backport of master feature in QGIS 2.18
DelazJ delazj at gmail.com
Tue Oct 18 02:30:57 PDT 2016
2016-10-18 2:02 GMT+02:00 Jürgen E. Fischer <jef at norbit.de>:
> Hi Even,
> On Thu, 13. Oct 2016 at 12:18:38 +0200, Even Rouault wrote:
> > - this PR adds new strings to translate (the DBManager changes might
> also).
> > Will translators do another round of translations for 2.18.x ? If not,
> this
> > might not be material appropriate for 2.18.x
> Transifex is already target for QGIS3 (as it sticked with master).
@Jürgen, are you sure about that?
Looking at the metadata of this new string in Transifex (
https://www.transifex.com/qgis/QGIS/translate/#fr/qgis-application/96618210
- sorry, it may not be visible to all), it appears that its source is
../src/ui/qgslabelingguibase.ui:4009
While https://github.com/qgis/QGIS/blob/master_2/src/ui/
qgslabelingguibase.ui#L4009 leads to the same strings,
https://github.com/qgis/QGIS/blob/master/src/ui/qgslabelingguibase.ui#L4009
doesn't.
>   For
> master_2, we talked about returning to the old scheme (ie.
> scripts/update_ts_files.sh and committing language update individual).
As stated above, I don't know if this decision is effective but I'm not
sure translators were informed about it. Afaics, I didn't see such
information and believed that (if my previous assumptions are false) I was
translating the next release (2.18) in Transifex and not the one after. And
unfortunately I may not be alone.
Regards,
Harrissou
> > - as we are in 2.18.0 feature freeze, must I wait for 2.18.0 to be
> released
> > before backporting (depending on previous question) ?
> When we decided on the time frame for 2.18 in Bonn, we also decided that
> you
> can add your geopackage improvements into 2.18.1 and I can add DWG support
> once
> it ready - regardless of the feature freeze that normally applies to
> releases.
> IMHO it shouldn't be applied now before 2.18 is released.
> Jürgen
> Jürgen E. Fischer           norBIT GmbH             Tel.
> +49-4931-918175-31
> Dipl.-Inf. (FH)             Rheinstraße 13          Fax.
> +49-4931-918175-50
> Software Engineer           D-26506 Norden
> http://www.norbit.de
> QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161018/0e561560/attachment-0001.html>
