[Qgis-developer] Add scripts from file Processing
matteo
matteo.ghetta at gmail.com
Tue Oct 18 02:55:40 PDT 2016
Hi devs,
I'm trying to duplicate the "Add script from file" in Processing also
for R algorithms.
I'm struggling with an error that happens both with "my" code but also
with the default "Add script from file" method.
When you click the "Add script from file" menu a dialog opens and you
can browse for the scripts. Here the problem, if you click both on OK
and Cancel the following error appears:
An error has occurred while executing Python code:
ValueError: need more than 0 values to unpack
File
"/home/matteo/.qgis2/python/plugins/processing/gui/ProcessingToolbox.py",
line 276, in executeAlgorithm
action.execute()
File
"/home/matteo/.qgis2/python/plugins/processing/script/AddScriptFromFileAction.py",
line 57, in execute
self.tr('Script files (*.py *.PY)', 'AddScriptFromFileAction'))
Obviously I get the same error for my code because I took that code as
template.
I cannot fix it, someone has an idea?
Thanks
Matteo
