[Qgis-developer] Building and debugging QGIS on Windows x64
Casper Børgesen (CABO) CABO at NIRAS.DK
Wed Oct 19 02:48:32 PDT 2016
Hi Jürgen
I start Visual Studio from the same command prompt as I start cmake-gui so I will have the same environment variables for both programs.
The change to pyuic-wrapper.bat proposed by Frits does work for now, but I will have to perform the changes each time I update the source code from github, which seems like the wrong solution.
Regards, Casper
-----Original Message-----
From: Qgis-developer [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of Jürgen E. Fischer
Sent: 19. oktober 2016 10:15
To: qgis-developer at lists.osgeo.org
Subject: Re: [Qgis-developer] Building and debugging QGIS on Windows x64
Hi Casper,
On Wed, 19. Oct 2016 at 07:51:54 +0000, Casper Børgesen (CABO) wrote:
> Thanks for the clarification regarding "debug"/"RelWithDebInfo", now I
> know that I can just continue debugging with "RelWithDebInfo".
> With respect to "cmake --build %BUILDDIR% --config %BUILDCONF%", I am
> following the  steps of INSTALL and I use VS2010 Express to build.
Are you starting VS from the batch file as proposed in INSTALL ("Now close cmake-gui and continue on the command prompt by starting vcexpress.")?  I guess you don't.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
