[Qgis-developer] Building and debugging QGIS on Windows x64
Jürgen E. Fischer
jef at norbit.de
Wed Oct 19 01:14:38 PDT 2016
Hi Casper,
On Wed, 19. Oct 2016 at 07:51:54 +0000, Casper Børgesen (CABO) wrote:
> Thanks for the clarification regarding "debug"/"RelWithDebInfo", now I know
> that I can just continue debugging with "RelWithDebInfo".
> With respect to "cmake --build %BUILDDIR% --config %BUILDCONF%", I am
> following the steps of INSTALL and I use VS2010 Express to build.
Are you starting VS from the batch file as proposed in INSTALL ("Now close
cmake-gui and continue on the command prompt by starting vcexpress.")? I guess
you don't.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161019/d2aea586/attachment.sig>
