[Qgis-developer] Add some postgresql PKI authentication tests to Travis
Sandro Santilli
strk at kbt.io
Thu Oct 20 03:24:30 PDT 2016
On Thu, Oct 20, 2016 at 12:05:17PM +0200, Alessandro Pasotti wrote:
> The alternative is to run another pg instance on another port and configure
> it to use ssl/PKI, and I know that this works because I've tested it
> locally but there might be other implications/problems that I've not
> considered.
I can't imagine any problem, other than eventual hard-coding of
connection parameters in tests (which should be fixed, if present)
--strk;
