[Qgis-developer] Custom symbol path for QGIS server in mixed environment
Andrea Peri
aperi2007 at gmail.com
Fri Oct 21 02:31:56 PDT 2016
Hi Paolo,
this is a sample from the qgis.ini in ou qgis-server environment.
It map two paths for svg: the svg for our Geological DB and the path
for out DBTopographics 2K scale DB.
[svg]
searchPathsForSVG=/home/...path-to.../qgis-settings/svg/simbologie_continuum_geologia_regione_toscana|/home/archivio/server/qgis-settings/svg/simboli_dbt10k_rt_svg|/home/...path-to.../qgis-settings/svg/simboli_rt_dbt2k_v0
every single path is separated using a | char
regards,
A.
2016-10-21 9:16 GMT+02:00 Paolo Cavallini <cavallini at faunalia.it>:
> Hi all,
> I have a project with custom symbols stored in a path on a Windows
> machine, in a location of the type E:\symbols\svg. I need to use these
> for a server project. I added the conf on the Debian server:
> mkdir -p /qgis_conf/QGIS
> nano /etc/apache2/sites-enabled/nameofthevirtualhost
> SetEnv QGIS_OPTIONS_PATH "/qgis_conf/"
> chown www-data /qgis_conf
> nano /qgis_conf/QGIS/QGIS2.ini
> # add:
> [svg]
> searchPathsForSVG=/path/to/svg1|/path/to/svg2
> but I do not know how to map the desktop path to the server one: any hint?
> Thanks a lot.
> Paolo Cavallini - www.faunalia.eu
> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
> https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Andrea Peri
qwerty àèìòù
