[Qgis-developer] Custom symbol path for QGIS server in mixed environment
Paolo Cavallini
cavallini at faunalia.it
Fri Oct 21 03:00:42 PDT 2016
Il 21/10/2016 11:31, Andrea Peri ha scritto:
> Hi Paolo,
> this is a sample from the qgis.ini in ou qgis-server environment.
> It map two paths for svg: the svg for our Geological DB and the path
> for out DBTopographics 2K scale DB.
> [svg]
> searchPathsForSVG=/home/...path-to.../qgis-settings/svg/simbologie_continuum_geologia_regione_toscana|/home/archivio/server/qgis-settings/svg/simboli_dbt10k_rt_svg|/home/...path-to.../qgis-settings/svg/simboli_rt_dbt2k_v0
> every single path is separated using a | char
Thanks Andrea. What is your Windows dir, and how do you match the two?
All the best.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
