[Qgis-developer] Custom symbol path for QGIS server in mixed environment
Paolo Cavallini
cavallini at faunalia.it
Fri Oct 21 06:43:05 PDT 2016
Hi Andrea,
aparently qgis does not see the environment I defined. How did you
define it? Did you follow:
nano /etc/apache2/sites-enabled/nameofthevirtualhost
SetEnv QGIS_OPTIONS_PATH "/qgis_conf/"
Thanks.
Il 21/10/2016 11:31, Andrea Peri ha scritto:
> Hi Paolo,
> this is a sample from the qgis.ini in ou qgis-server environment.
> It map two paths for svg: the svg for our Geological DB and the path
> for out DBTopographics 2K scale DB.
> [svg]
> searchPathsForSVG=/home/...path-to.../qgis-settings/svg/simbologie_continuum_geologia_regione_toscana|/home/archivio/server/qgis-settings/svg/simboli_dbt10k_rt_svg|/home/...path-to.../qgis-settings/svg/simboli_rt_dbt2k_v0
> every single path is separated using a | char
> regards,
> A.
> 2016-10-21 9:16 GMT+02:00 Paolo Cavallini <cavallini at faunalia.it>:
>> Hi all,
>> I have a project with custom symbols stored in a path on a Windows
>> machine, in a location of the type E:\symbols\svg. I need to use these
>> for a server project. I added the conf on the Debian server:
>> mkdir -p /qgis_conf/QGIS
>> chown www-data /qgis_conf
>> nano /qgis_conf/QGIS/QGIS2.ini
>> # add:
>> [svg]
>> searchPathsForSVG=/path/to/svg1|/path/to/svg2
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
