[Qgis-developer] Custom symbol path for QGIS server in mixed environment
Andrea Peri
aperi2007 at gmail.com
Sat Oct 22 02:07:01 PDT 2016
Mmmm .... i guess no.
I define an environment variabile in the
Service file that start the web engine.
Also set the web engine to retrieve the vars from environment.
Il 21 ott 2016 15:43, "Paolo Cavallini" <cavallini at faunalia.it> ha scritto:
> Hi Andrea,
> aparently qgis does not see the environment I defined. How did you
> define it? Did you follow:
> nano /etc/apache2/sites-enabled/nameofthevirtualhost
> SetEnv QGIS_OPTIONS_PATH "/qgis_conf/"
> Thanks.
> Il 21/10/2016 11:31, Andrea Peri ha scritto:
> > Hi Paolo,
> > this is a sample from the qgis.ini in ou qgis-server environment.
> > It map two paths for svg: the svg for our Geological DB and the path
> > for out DBTopographics 2K scale DB.
> > [svg]
searchPathsForSVG=/home/...path-to.../qgis-settings/svg/simbologie_continuum_geologia_regione_toscana|/home/archivio/server/qgis-settings/svg/simboli_dbt10k_rt_svg|/home/...path-to.../qgis-settings/svg/simboli_rt_dbt2k_v0
> > every single path is separated using a | char
> > regards,
> > A.
> > 2016-10-21 9:16 GMT+02:00 Paolo Cavallini <cavallini at faunalia.it>:
> >> Hi all,
> >> I have a project with custom symbols stored in a path on a Windows
> >> machine, in a location of the type E:\symbols\svg. I need to use these
> >> for a server project. I added the conf on the Debian server:
> >> mkdir -p /qgis_conf/QGIS
> >> chown www-data /qgis_conf
> >> nano /qgis_conf/QGIS/QGIS2.ini
> >> # add:
> >> [svg]
> >> searchPathsForSVG=/path/to/svg1|/path/to/svg2
> Paolo Cavallini - www.faunalia.eu
> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
> https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161022/bf884c99/attachment.html>
