[Qgis-developer] WIP: QGIS Server refactoring
Neumann, Andreas
a.neumann at carto.net
Fri Oct 21 09:22:29 PDT 2016
ok good - just wanted you to be aware of these upcoming changes. Not
that you will be surprised.
Have a nice weekend!
Andreas
On 2016-10-21 18:10, David Marteau wrote:
> Hi Andreas,
> We know that it will be premature to write code that dépends on the qgis core api and that we have to wait that things stabilize on this side and that no refactoring of the services can occurs without the refactoring of Martin.
> The part of the code we wand to start is the support machinery for dynamic loading and registering of services and eventually the supports for the plugins.
> For this part, we do need to rely on anything from the qgis core functionalities and thus Martin Dobias's refactoring can go at its own pace.
> David
> Le 21 oct. 2016 à 17:54, Neumann, Andreas <a.neumann at carto.net> a écrit :
> Hi René-Luc,
> hm - I am not sure if this is good timing.
> Martin Dobias will refactor the layer tree extensively to allow a better QGIS server code design. It is his proposal he submitted for the QGIS grants. The swiss QGIS user group, potentially together with the german QGIS user group will pay for his work, because it didn't make the grant in the voting, but we still thought it is important work to be done.
> I guess it would make sense to wait until his work will be finished and then start the QGIS server refactoring. However, it would be good to collaborate with Martin to make sure his refactoring is useful for the QGIS server refactoring.
> Greetings,
> Andreas
> On 2016-10-21 17:40, René-Luc Dhont wrote:
> Hi devs,
> We (David Marteau and I) will start the QGIS Server refactoring.
> The first step for us is to develop the *service register* like described in the QEP: QGIS server code refactoring for QGIS 3.0 https://github.com/qgis/QGIS-Enhancement-Proposals/issues/74
> To keep the developement open, we proposed to use a github repository to centralize *Pull Request* and development strictly on QGIS Server with a dedicated branch https://github.com/3liz/QGIS/tree/master_qgis_server
> We proposed to do so to have the possibility to broke the code but we will continue to merge master in it during the dev.
> We will open the right to other QGIS Server developers and be proud to review Pull Request.
> Our goal is to keep the functionalities, simplify the code and add modularity; to have something more maintainable, robust and expendable.
> Regards,
> René-Luc D'Hont
> 3Liz
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161021/56f8ceef/attachment-0001.html>
