[Qgis-developer] Processing takes a very long time to close the Options popup
gordon at shieldaig.com gordon at shieldaig.com
Wed Oct 26 13:38:18 PDT 2016
On 2016-10-26 16:32, gordon at shieldaig.com wrote:
> On 2016-10-26 13:18, Paolo Cavallini wrote:
>> Il 26/10/2016 19:04, roy roy ha scritto:
>>> Hi, not shure if this can be related to this issue i found today
>>> about SVG symbols Path:
>>> http://hub.qgis.org/issues/15759
>>> maybe you had hundreds of duplicated path(?)
>> checked, not
>> thanks
There is another SVG symbols issue in addition to Path, present in
QGIS 2.16 also, and that is the home directory path is incorrect and has
two // rather than one /,
eg.
/usr/share/qgis/svg/
/home/gordon/.qgis2//svg/
