[Qgis-developer] Processing takes a very long time to close the Options popup
Nyall Dawson
nyall.dawson at gmail.com
Wed Oct 26 13:58:58 PDT 2016
On 27 Oct 2016 6:38 AM, <gordon at shieldaig.com> wrote:
> On 2016-10-26 16:32, gordon at shieldaig.com wrote:
>> On 2016-10-26 13:18, Paolo Cavallini wrote:
>>> Il 26/10/2016 19:04, roy roy ha scritto:
>>>> Hi, not shure if this can be related to this issue i found today
>>>> about SVG symbols Path:
>>>> http://hub.qgis.org/issues/15759
>>>> maybe you had hundreds of duplicated path(?)
>>> checked, not
>>> thanks
> There is another SVG symbols issue in addition to Path, present in
> QGIS 2.16 also, and that is the home directory path is incorrect and has
two // rather than one /,
> eg.
> /usr/share/qgis/svg/
> /home/gordon/.qgis2//svg/
Can you try with 2.18/2.14.8. This issue was fixed recently, but since 2.16
is end of lifed it didnt receive the fix.
Nyall
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20161027/8b321404/attachment.html>
