[Qgis-developer] QtCreator and QGIS on ubuntu
Richard Duivenvoorde rdmailings at duif.net
Thu Sep 1 00:15:27 PDT 2016
On 01-09-16 08:09, Casper Børgesen (CABO) wrote:
> If I haven’t already got the QCA dependency, which library should I install?
Guessing you are building master_2 or other 2.x branch you probably need:
libqca2-dev (the qt4 version) (the dev files will pull in the lib itself
too)
And if I recall correct you also need the plugins package:
libqca-qt5-2-plugins (but not 100% sure)
if you build master (qt5, QGIS3) you need libqca-qt5-2-dev (and myabe
the plugins
Regards,
