[Qgis-developer] [WIP] project snapping settings
Mathieu Pellerin nirvn.asia at gmail.com
Fri Sep 2 05:27:50 PDT 2016
It'd be nice to move the "Snapping options" menu item to be located into
the Project menu (below or above the "Project properties" item). It doesn't
make much sense to have it located where it is ATM.
M
On Fri, Sep 2, 2016 at 6:30 PM, Denis Rouzaud <denis.rouzaud at gmail.com>
wrote:
> Hi all,
> Just to let you know, I am working on a new design to handle snapping
> settings.
> Settings are now handled in a core class attached to the project,
> similarly to QgsRelationManager. It will provide a nice API to deal with
> the settings and some useful signals.
> This means one will no longer have to change the project settings manually
> and take care of emitting the proper signal.
> Besides, there will be a new widget to define the settings. It will be
> quite flexible and can be shown in the status bar, tool bar, dock or
> dialog. Per layer config will use the legend layer tree.
> If the old snapper class is removed in the mean time, it will save me some
> time ;)
> Best wishes,
> Denis
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160902/9ddd2d01/attachment.html>
