[Qgis-developer] QGIS 2.16.1-2 Crashing on Loading GeoTIFFs
C Hamilton adenaculture at gmail.com
Fri Sep 2 09:21:39 PDT 2016
Attached is a very small test image. Incidentally, the problem is with QGIS
2.16.2-1 not 2.16.1. I have only tried this on Windows with the 32-bit
network installer. The problem is definitely with gdal. If I run gdalinfo
on the image from the OSGeo4W command shell it crashes. According to the
OSGeo4W Setup, I have gdal 2.1.1-1 installed.
Thanks!
On Fri, Sep 2, 2016 at 10:44 AM, Giovanni Manghi <giovanni.manghi at gmail.com>
wrote:
> Hi,
> > Has anyone encountered this yet? I am using the 32-bit Network
> Installer. I
> > think it started with the latest GDAL update. Loading a GeoTIFF fails on
> > both my machines. I had to go back to the long term release on my machine
> > that I use for actual work.
> any geotiff? could you eventually share one that does not work for you
> so we can test on 64bit and other platforms?
> cheers!
> -- g --
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160902/9d36b9dd/attachment-0001.html>
Type: image/tiff
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160902/9d36b9dd/attachment-0001.tif>
