[Qgis-developer] QGIS 2.16.1-2 Crashing on Loading GeoTIFFs
C Hamilton adenaculture at gmail.com
Fri Sep 2 09:25:12 PDT 2016
I don't know if this crash information is helpful.
Problem signature:
  Problem Event Name:    APPCRASH
  Application Name:    qgis-bin.exe
  Application Version:    0.0.0.0
  Application Timestamp:    57c0c24e
  Fault Module Name:    ntdll.dll
  Fault Module Version:    6.1.7601.23418
  Fault Module Timestamp:    5708a73e
  Exception Code:    c0000005
  Exception Offset:    000346f3
  OS Version:    6.1.7601.2.1.0.256.48
  Locale ID:    1033
  Additional Information 1:    1d0c
  Additional Information 2:    1d0c85114d5e995e150b85f0f1b98898
  Additional Information 3:    5dac
  Additional Information 4:    5dacaa43bc2311a4ec5a6b7872b77a7a
On Fri, Sep 2, 2016 at 10:44 AM, Giovanni Manghi <giovanni.manghi at gmail.com>
wrote:
> Hi,
> > Has anyone encountered this yet? I am using the 32-bit Network
> Installer. I
> > think it started with the latest GDAL update. Loading a GeoTIFF fails on
> > both my machines. I had to go back to the long term release on my machine
> > that I use for actual work.
> any geotiff? could you eventually share one that does not work for you
> so we can test on 64bit and other platforms?
> cheers!
> -- g --
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160902/c7c75de8/attachment.html>
